Fatal Error Installation Issue required NIPathsDir undefined NIMDFDIR
I get the above error message trying to install LabView 8.2 with local administrator rights.
Any idea
Thomas Tuch
(3,176 Views)
This error is actually due to a problem with Windows and not with NI software. There are three common causes for this error:
  • The CD-ROM or DVD-ROM drive letter has changed since a previous install.
  • You have changed the drive letter of the hard disk that the operating system is installed on, for example, drive C.
  • A registry key contains an incorrect value in a Data field.
Check out this link to find more help:
http://consumer.installshield.com/kb.asp?id=Q110636
(3,171 Views)
