Fatal Error in Timed While Loop
Hi!
Our application involving timed while loops has stopped responding.
We have been seeing increasing (and erratic) problem occurance and finally it precipitated.
DAQ operations outside the time loop continue to work.
A full description with error history, error messages and sample VI is at the thread:
http://forums.ni.com/ni/board/message?board.id=270&message.id=1337
We request urgent attention.
Gurdas
Gurdas Sandhu, Ph.D.
ORISE Research Fellow at US EPA
(3,820 Views)
Is the problem occuring when using timed while loops only, or for any type of DAQ application?
Has this happened before or is it the first time is happening?
Try installing the latest version of our drivers and see if that helps. If the error persists, try your boards in another computer and see if it gives you similar problems. Run example programs to see if the application you have is the one that has the problems.
Hope this helps,
LA
(3,801 Views)
LA, thanks.
The link (see above) to another thread describes status of prblem as of now and also answers your suggestions.
Could you please check the link and let me know if any other possibility comes to your mind.
The problem continues.
- Gurdas
(3,786 Views)
It is not efficient to create multiple threads for the same issue.
Please keep all information and responses in the original thread.
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
(3,769 Views)
Phillip,
I fully agree with you and am sorry for the double threads.
It so happened that the first thread was created in PXI and with a subject line that might be incorrect.
So, this thread in LV.
Best,
Gurdas
(3,755 Views)
Ohh, I see - my bad!
I hope that you will get the help you need.
Thinkbot Solutions
(3,738 Views)
