Fatal Error message when trying to install software
I get a "Fatal Error: Required NIPathsDir property CVIDIR is undefined"....   when running the Labview 8.2.1 installer ..  The solution for KnowledgeBase article on this problem was either incorrect or was unclear in exactly how the solution was to be implemented...
(3,674 Views)
Do you have a "My Documents" folder on your hard drive at C:\Documents and Settings\your user name\My Documents?  What is the version of your NI Installer?  Also, are you logged in as an Administrator?
Cheers,
Clint M
(3,660 Views)
ClintM....
Yes .... I have a "My Documents" folder in the standard location and I am logged on as administrator....  I've got the "Academic Site License Spring 2007 Labview Core"   installer disc (DVD) but I can't find a version # of the installer.   I'm trying to install Labview 8.2.1 on a Sony Vaio Laptop....
Engtech4
(3,643 Views)
