Fatal Internal Error : "OMUDClassMgr.cpp". Line 1128
I received the following message:
Fatal Internal Error : "OMUDClassMgr.cpp", 1128
LabVIEW version 8.2.1
I was trying to build an application using the application builder.
Has anyone else had this issue?  What needs to be done to fix this.
(3,127 Views)
This was reported to R&D (#4ALB7O89) for further investigation.  Are you able to reproduce this problem with the same VI?  Are you able to build an application with a simple VI?
Elizabeth S.
(3,114 Views)
I was able to reproduce this error in the same project when trying to build the same VI.  I tried to build several other VIs and the error was not reproduced with any of the other projects.
(3,084 Views)
If possible, please attach any files necessary to reproduce this and attach them to this forum thread.  If we can't reproduce the problem internally it will be very difficult to identify and fix the issue.  Thanks!
(3,076 Views)
