Fatal Internal Error: "drawmgr.cpp"
Strange thing just happened...
I've got a LabView compiled app running and viewing it over Remote Panel.  After 1-2 minutes, the app (not the view running in Internet Explorer) popped up with a message 'Fatal Internal Error: "drawmgr.cpp", line 2937'!  It appeared that the app was still running (graphs were updating, etc).  When I pressed the [OK] button, the view that was in the IE window reset -- I didn't notice anything happen to the app itself.
This only started happening today, and yesterday, my system updated itself to Vista64 sp2 -- wondering if that (probably) had something to do with it?
Any ideas out there?
(5,244 Views)
Hi Steve257,
I need to know some more information.
What version LabVIEW do you have and on what operating system?
Flash P
(5,229 Views)
Sorry I didn't include that info...I'm using LabView 8.51 running on Vista64.
(5,220 Views)
Most likely one or more objects on the front panel are causing the video card to return this error. This may be due to a change in a configuration during the OS upgrade. One possible solution may be to try disabling acceleration of your video card or installing newer video card drivers however you may want to read the following documents on trouble shooting this error.
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/01b186b5ceb1d07786256747000f4319?O...
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/16cf1334d094a4f6c1256be3
0074b9fe?OpenDocument
Other resources can be found on the ni.com website by clicking the support tab at the top of the home page. Then search from Technical Resources at the top of the page for your topic. I hope these resources help! Let me know if you need any other support with this issue.
(5,211 Views)
