Fatal Internal Error: "memory.cpp", line 1038
We have recently run into a memory.cpp line 1038 error.  We have seen a memory.cpp error a while back where tabbing off of a string control on a remote panel in an event structure that has "Lock front panel until the event case for this event completes" is marked, but this is not the case here.  Our application is simply running responding to HTTP requests and then crashes with this error.  Any assistance is appreciated.
Thank you,
Chris Bauer
(2,928 Views)
Hello Chris, a lot of times these errors are really tricky to track down.  It would probably help the Applications Engineer who will help out on this forum if you could post a VI which reproduces the problem, or if you aren't allowed to post your code, if you can put some instructions on how to create this "from scratch".  The error log file that is generated can help too, but often the best troubleshooting comes from trying to find out what exact set of operations lead to the error.
Thanks, and hope that we can get to the bottom of this for ya-
Travis M
LabVIEW R&D
(2,913 Views)
Yeah, that's the problem it appears to happen randomly.  We are currently trying to get the code to the most simple form that recreates it.  That way we can post it.  Unfortunately, we can not reliably reproduce the error.  I hope that we will get to that point and then we will be able to post some code.
(2,911 Views)
Hello Chris,
This is Dominic L. from Applications Engineering at National Instruments. We would be really curious to know what you find. Please let us know as soon as possible so we may find a fix.
Thanks so much and have a great weekend.
Best Regards,
Dominic L.
(2,892 Views)
