Fatal Internal Error
I have to control a hydraulic circuit choosing one of two different pumps.
It works but when I close the vi Labview gives me this error: "Fatal Internal Error.cpp" , line 437.
I think it should be depends on some mistake in my code.
This is the vi (Labview 8.6)
Labview 8.6
PXI-1042Q
PXI-6704
PXI-6229
(4,355 Views)
See this
Message Edited by muks on 03-12-2010 02:47 PM
(4,346 Views)
Hi Pablo,
as Musk pointed out, the Fatal Internal Error: "MemoryManager.cpp", line 437 could be related to some reported bugs if you use feedback nodes, fixed-size arrays or remote panels.
Anyway I had a look at your VI and it seems you don't use any of these structures (or maybe are you using remote panels?)
Moreover, I can't run your VI since there are some missing subVIs (as for example Acquisition Module.vi, Taratura regolatore.vi, etc.), so I don't know if I can reproduce this error with LV 8.6. If I can reproduce it, there is the possibility that a newer version of LV has resolved the problem.
If you post the missing subVIs I can test them.
Serena M.
(4,308 Views)
Hi Seren,
But I am muks...... :smileywink:
(4,304 Views)
Hi reikira.
Here is the rest of the code. I'm thinking the problem is how I choose the output, even if I've never changed the output while the main vi is running.
I've tried to implement a new code, but i've had others errors, this is not good because I've a deadline (I must finish my thesis before 20th of april :smileymad:)
Anyway, let see.
Thank you 😉
Labview 8.6
PXI-1042Q
PXI-6704
PXI-6229
(4,284 Views)
Forgot the attachment?
(4,281 Views)
Opss! ^_^'
Labview 8.6
PXI-1042Q
PXI-6704
PXI-6229
(4,267 Views)
