Fatal Internal error: "oleautomgr.cpp", line 2832 when sending data by means of ActiveX methode
I have experienced  error "Fatal Internal error: "oleautomgr.cpp", line 2832" during sending data to CAN card IXXAT iPCI-I XC16/PCI. LabVIEW communicates with that card by means of ActiveX methodes via "VCI Wrapper" which is COM object interface. Mass compiling of the project does not help. Card is initialized and configured propely. The driver card is working propely.
LabVIEW version is 8.5
The efect of that error is that labview completly shot down.
I appraciate any suggetions
thanks a lot
(2,863 Views)
Please try to reinstall the drivers for the CAN card, then make sure you close all references to the ActiveX control (at all levels) using the Automation Close primitive in LabVIEW.
Emil
(2,831 Views)
