Fatal internal error :"fpsane.cpp", line 280 or line 281
Hi All
I meet a problem that convert LV2010's vis to LV86.
I use LV2010 to save vis as previous version LV86, then use LV86 to open vis that have been save as version LV86.
There always come out this error :Fatal internal error :"fpsane.cpp", line 280 or Fatal internal error :"fpsane.cpp", line 281
Anyone can help me ?
Thank you in advance !
(2,730 Views)
This error coming pretty often when I tried to downgrade VI, whcih contains Vision VIs. The only one recommendation - try to delete parts of your Block Diagram, then downsave to previous version. So, you will found block which is caused such exception. No other way unfortunately.
Andrey.
(2,718 Views)
Accepted by topic author Water1
Hi , Thank you .
I found a failed root .
LV2010 's image control refnum is NOT compatible with LV86's .
(2,703 Views)
