Fatal internal error : "memory.cpp", line 1704
When I am trying to open my solution, an error occurs and Labview stops running. This happens only when I try to open one of my VIs. (Other VIs don't give any error.)
This error appeared after I saved my solution and close it then I try to open it again. The program normally saved and closed the solution but didn't open it again.
I need urgent help.
Thanks.
Message Edited by turkey on 02-02-2007 01:08 AM
Message 1 of 8
(4,438 Views)
Hello turkey,
I searched in our database and was able to find an existing error log report with the same cpp file and line number. Unfortunately, there was not enough information for us to reproduce the issue, so I do not have any sort of workaround for you.
However, please kindly attach the VI in your response to this, and I will see what we can do to update the Corrective Action Request and hopefully get your VI back.
-Sam F, DAQ Marketing Manager
Message 2 of 8
(4,416 Views)
First of all I want to thank you for your interest.
You have wanted me to send you the VI that error occurs. But it is the main part of a big project and I hope you understant that this is a top secret machine vision project and I cannot publish it. If it will be sufficent, maybe I can send only the main VI (not subVIs).
Sorry for that situation.
Best regards.
Zafer DEPE
R&D-Application Engineer
E3TAM A.Ş.
İstanbul/Turkey
Message Edited by turkey on 02-05-2007 09:46 AM
Message 3 of 8
(4,408 Views)
Hi turkey,
I understand your situation, that's fine.
If you need to take out the subVIs in order to send it along, that would be fine - assuming that the same error occurs without the subVIs.
Kind regards,
Message 4 of 8
(4,400 Views)
Hi sam,
I have taken the reply below from RMA support of NI Arabia. As you see, that error is a bug till Labview 7.1 and resolved in Labview 8. Also there is another way to resolve it. If this error occurs agin, I will try this solution and I should send you the VI. (I have written the VI again from my backups). Besides, we are the distributor of NI in Turkey and we are getting to start using Labview 8.2 in new projects. I hope any error occurs. Thank you very much.
Regards...
Zafer DEPE
E3TAM A.Ş.
"Re: RMA Support E-Mail: Fatal internal error : "memory.cpp", line 1704
The problem that you have reported has been a bug in all versions of
Labview till Labview 7.1 and was resolved in Labview 8. The course of
action would be as follows-
1. We would need to uninstall and reinstall Labview on your system. The
uninstallation procedure would be done through the MSI Blast facility
that
I am attaching with this mail. Please select all National Instruments
Software when you open this utility ie Labview and Device drivers, if
you
have any other NI Software such as CVI installed, please let do not
uninstall the same. After this please go ahead and install Labview and
Device Drivers from the CD's you have."
Message Edited by turkey on 02-07-2007 05:25 PM
Message 5 of 8
(4,386 Views)
I am using LV 2009 and I am also getting same error when I start executing steps on TS 4.2.1. Please find the attched logs. Further, I could not run anything in TS and need to restart the PC to re-run the sequence after everytime this error occurs.
We have transited through LV 8.0, 8.2, 8.5 and now 2009 over past 4 years for our project and this is the first time I could see this error.
Please help.
Thanks.
Message 6 of 8
(3,806 Views)
One more thing... I get this error even when I unload the modules from TestStand.
Thanks.
Message 7 of 8
(3,759 Views)
Dont place the same question is related threads.
Continued here.
Stick to that thread
Message 8 of 8
(3,736 Views)
