Fatigue Analysis using Strain Gauges for an Aircraft
Hi all.
I am a new staff in the company. My task is to make a fatigue analysis using 14 strain gauges that are installed on the aircraft. My supervisor asks me to use Columbia Strain Gauge (DTD2684) and NI data logger to store the fatigue reading. After landing, I need to collect the results and interface it using Labview software.
So, I have a problem in the fatigue analysis using Labview because I very fresh about this software even though I have made a review and research almost two weeks. How can I links the Columbia strain gauges and NI data logger?
Thank you for helping.
(3,456 Views)
Accepted by topic author ASyakirin
Hi AS,
Usually you need some (insulated copper) wires and a DAQ device…
As you get paid for this task: why should we do your work? You might pay an advisor to do so…
Don't hesitate to ask your questions here, but then you need to provide more information about your task (like available DAQ device, LabVIEW version) and keep your questions specific)!
(3,413 Views)
I am using old version of labview which is Labview 2012 (from my company's laptop). My job is to measure the tension or pressure of the aircraft when the plane was flying. There are 14 strain gauges that act as an input mechanism. The input data will be recorded and saved into the data logger. After landing, all the data and readings will be analyzed in the labview software. Since my labview lesson was scheduled end of this month, I'm deciding to make a study about this task earlier.
My company just gives me these links as a reference about the task:
1. http://www.ni.com/white-paper/10991/en/
2. https://www.crlsensors.com/prodDocs/dtd2684-11.pdf
Thank you for the quick response..
(3,401 Views)
Hi AS,
Then you might start with all those FREE LabVIEW learning resources offered at the top of the LabVIEW board! (Or here!)
As can be seen in the NI AppNote you need some real hardware DAQ device. Which one will you use? (Once you know this: read its manual!)
(3,392 Views)
Although the configuration of your system is different, I am sure this guide on how to connect strain gauges to a DAQ will be helpful http://www.ni.com/getting-started/set-up-hardware/data-acquisition/strain-gages
Joe
(3,359 Views)
thanks Joebailey
(3,343 Views)
