Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Faulty Analog Output
June Kiat
Member
08-08-2002
04:47 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Can anyone please take a look at my VI and see whats wrong with it?? I'm unable to produce any analog output signal for my DAQ card under DAC0OUT. Could it be my settings instead? Help me!!! My brain is exploding!
Test1.vi 140 KB
0
Kudos
Message
1
of 2
(2,686 Views)
Reply
Re: Faulty Analog Output
Ben
Knight of NI
08-09-2002
07:27 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hi June,
The VI you are using to write the output should have the iteraction wired.
This value tells the VI that it should init the device when the values is zero.
All other calls will re-use the previously configured channel.
On another note;
You could be setting yourself up for trouble by saving to the LV supplied .LLB's.
Ben
Retired Senior Automation Systems Architect with
Data Science Automation
LabVIEW Champion
Knight of NI
and
Prepper
LinkedIn Profile
YouTube Channel
0
Kudos
Message
2
of 2
(2,686 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
