Feature RFD: Behavior when inserting a bundle by name into a cluster wire
Assume you have a cluster wire. Now I want to insert a bundle by name to change a value of that cluster data.
Current (LV7.1) behavior :  the wire breaks because the cluster is wired to the bundle input
Wouldn't it be nice if the cluster is wired to the cluster input ?  (Your vi will still break because an input is required, but not the cluster wire)
Greetings from Germany
Henrik
LV since v3.1
(3,123 Views)
Hi Henrik
I just checked this in my LV8.0 - it's still the same.
Great idea - you get a full 5 stars from me;).
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,117 Views)
Hi guys,
Thanks for the feedback.  LabVIEW R&D is aware of this feature request, so perhaps we will see this improved functionality in a future LabVIEW version.
Keep the suggestions coming,
-D
(3,100 Views)
I recall this feature request from way back in LabVIEW 5. Still waiting for it... (Not holding my breath.)
(3,092 Views)
