Feedback Node Crash
I seem to have stumbled across a bug in LabVIEW 2010. I'm trying to create a subvi that loops FP read, with the FP refnum stored in a feedback node. Unfortunately every time i wire up the feedback node and try to save the vi, LabVIEW crashes. It also crashes if i try to run the vi. Fortunately it does so gracefully and my other vi's can be recovered, but does anyone know if there's a workaround to actually implement this?
Related vi attached.
LabVIEW 2010 (v 10.0f2), 32-bit running on Win XP
(2,625 Views)
Does it give any error codes? I don't have your subVI. The main one is simple enough. Try recreating it from scratch. Sometimes VIs get corrupted or just go insane.
LabVIEW 2012
(2,616 Views)
