Feedback Nodes: Global Initialization Differences for LabVIEW FPGA?
Question:
When working with LabVIEW FPGA, is there any difference between the initialization options for feedback nodes when a constant is wired, specifically between the "Initialize On Compile Or Load" and "Initialize on First Call" options? I'm interested in the potential differences with regard to behavior/functionality as well as FPGA implementation considerations (e.g. FPGA resources, timing, etc.).
Initial Thoughts:
My instinct says that "Compile or Load" sets these nodes to be hard wired such that the only way to reset them is to re-download the bitfile to the FPGA. As such, I thought it would naturally ignore the reset method, but then there is a checkbox in the feedback node properties specifically to ignore the reset signal when this option is selected. A secondary question is whether this option can be safely checked if I'm re-downloading the bitfile every time I use it anyway and never use the Reset method.
For "First Call", it's hard for me to understand what this might mean for an FPGA bitfile. Is it each time I call Run/Abort in the Host? Or is it each time the bitfile is loaded, in which case how is it any different from the "Compile or Load" option?
(1,531 Views)
If you abort and re-run your bitfile without re-deploying it, you will have shift registers which retain old values upon restarting if you enable "compile" initialisation. If these are simply delays in computations, it probably won't be a huge deal but if they're information for state machines, weird things might happen.
"Ignore reset" kind of does sound like it does the same thing so I think there may be a difference between a reset and a re-deploy. Don't have experience here, sorry.
We always deploy upon restart, so we always choose the "init on compile" and "ignore reset" options.
(1,523 Views)
