Field Point: Using Multiple FP-TC-120
I'm fairly new to this. I've used the example fp_tc_120.vi to get started. But now I'm trying to read in from two FP-TC-120 units.
There is a note saying: "Use only one FP Open passing the FP refnum thoughout your VIs. Use only one FP Close to shutdown your entire FieldPoint session."
How would I go about reading from the two units if I can only pass one refnum? Thanks in advanced.
(3,130 Views)
Please move this thread to the Field Point section.
(3,118 Views)
I'm not sure which LV or FieldPoint Version you have. I habe FP 4.1 with LV 7.1.1.
The help here is more precise. Meant is that you should open one iak-File only with one FP Open call. Then you should use the Refnum in your program.
The iak-File is created using MAX. A iak-File is the representation of your FieldPoint hardware. Since you have two TC-120 units you have these in your iak-File. They have two different modul adresses.
Look into the picture about how to organize your programm flow.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(3,107 Views)
Thanks. The flow chart helps explain it.
We're still using the older version of LabView; v6.1.
(3,100 Views)
