FieldPoint and Enet-RS232 converter
Hi all,ces
How can I drive ENET-232/2 from the application, embedded into the FP-2010? I'd also like to know where to get more detailed description about ENET-232 devi
(2,721 Views)
I do not believe that you will be able to communicate to an ENET-232 device from an embedded application in a FP-2010. The ENET-232 device requires that you use NI-VISA in LabVIEW to communicate to the device. However, the FP-2010 currently does not support NI-VISA. Here are a few links to more information regarding the ENET devices:
ENET-232 Series and ENET-485 Series User Manual for Windows 2000/NT 4.0 and Linux x86/Solaris 2.x
Using the ENET-232 and ENET-485 Series on Windows 9x
Hope this helps,
Mike
(2,721 Views)
