Fieldpoint & Create Tag for a selection of channels
Is it possible to create a single tag for a Fieldpoint Module that has a
selection of channels?
I know that you can select all of the channels of a module, or an
individual channel.
At the moment I am creating tags for each channel from the modules that I
require and then using "For Loops". This is not too bad for just a couple
of channels on a module, but when you have many modules it seems rather
cumbersome. This is especially a nuisance for the CTR modules that have a
mixture of channel types and do not take the "all" option for the channels.
Cheers
Stephen
Stephen Moore
Wellman CJB Ltd, Airport Service Road, Portsmouth, Hampshire PO3 5PG, UK
Tel:Direct +44(0)23 92629227 +44(0)23 92664
911 Fax: +44(0)23 92697864
(2,741 Views)
Stephen,
I have done this with a Fieldpoint AI module, and I assume it will work with others.
You need to use FP Explorer (or whatever the FP configuration utility is called) to define your new group of channels with a single name. Basically, you create a new tag then check all the channels you want to use.
This is much more efficient than trying to read them one at a time.
Bruce
Bruce Ammons
Ammons Engineering
(2,741 Views)
