Fieldpoint io currupting my graph
Hi, recently i manage to get my Datalogger running. to do what it needs to, which is great 🙂 i modified it today to work using different Compact fieldpoint modules, by modifying the fieldpoint  io address e.g. to look at PAC1 instead of PAC2. And for some reason, on one of my graphs, two of the axis for graphing results have stopped working. But yet it works fine when i revert back to using PAC2. Is this a labview error??
Stu
(2,857 Views)
Hi Stu,
It is difficult to tell what could be causing this problem from the information you have provided. Could you please detail your hardware and software set up. Do any error messages appear?
Many thanks,
Ben L
Field Engineer
(2,801 Views)
Solved Smiley Happy
(2,788 Views)
