File Explorer window in tree control
Hi all,
I am trying to get the feel of windows file explorer in a tree control. I was successful somewhat in listing the files, but I was unable to make the parent-child relation correctly. I have attached one jpg file of file explorer. I would like to replicate the same in a tree control.
I used recursive file list function during my trial.
Please suggest a good option. (I have seen the NI example, but its too slow and I would like to make it simple string based application(not realtime folderlisting)).
Message Edited by Parag D on 12-15-2009 03:54 PM
-FraggerFox!
Certified LabVIEW Architect, Certified TestStand Developer
"What you think today is what you live tomorrow"
Message 1 of 10
(7,917 Views)
it is possible to have a explorer. but it gets a little complicated depending on the level of child items in a parent.. For example a parent having 15 (a random number) of childs and each of these childs are having 15 other subchilds and so on, which ultimatly results in a complete slow down of the application
Also if you would like to populate the "symbols" for the corresponding items things goes from bad to worst
Regards
Guru (CLA)
Message 2 of 10
(7,867 Views)
I was implementing a recursive kind of logic.
Say c:\abc\xyz\1\2\file.vi is the path we need to list
then, we would start off with file.vi making the child(and so on the other files which are listed after the last "\" from the recursive folder list function), and then making all the previous parent of parents.
so here,2 is a child of 1, which is a child of xyz and so on.....
-FraggerFox!
Message 3 of 10
(7,863 Views)
Asi told you.. if you dont have a very good algorithm to do it , it gets complicated depending up on the depth of the path.
here are some example that may help you out
Guru
Regards
Guru (CLA)
Message 4 of 10
(7,839 Views)
Thanks!
Will try that out!
-FraggerFox!
Message 5 of 10
(7,833 Views)
I'm attempting to do the same thing, and Guruthilak's, or FraggerFox's code look like great starting point(s).  Unfortunately, I only have LabVIEW 7.1  (can't use newer sadly).  Any chance someone could save the files in LV 7.1 compatibilty mode?
RustEE
Message 6 of 10
(6,353 Views)
Hi rustEE
You can get help to convert code here:
Version Conversion
Regards
Frank R.
Message 7 of 10
(6,327 Views)
Oops, sorry I'm new to the forums, thank you.
Message 8 of 10
(6,314 Views)
Actually, I don't think asking for an older version of LabVIEW files from within the message thread where they were first posted is a bad thing.
I consider the Version Conversion forum primarily a location for requesting random conversions for people's own VI's when they get stuck moving being different systems and don't have access to the newer version to do a backsave.  Or trying to open up a very old version of a VI that can't be opened up in newer LabVIEW.
Unfortunately, I can't help you because I don't have LabVIEW 8.0 installed on any PC's anymore which is needed to do the final save to get it back to 7.1
Message 9 of 10
(6,290 Views)
For anyone who may stumble accross this thread looking for the Tree Control API in LabVIEW 7.1, here is a link to the Version Conversion thread where they ended up.  Thanks to K C for converting the files.
http://forums.ni.com/t5/Version-Conversion/Tree-Control-vis-From-8-2-to-7-1/td-p/3094098
Message 10 of 10
(6,269 Views)
