File Locking and LabVIEW
I am writing a bunch of data to a file from a LabVIEW VI. I am
using the standard file I/O routines. I would like to view this
file with another program while LabVIEW is running -- this is
no problem with programs that open the file for reading only, but
most programs attempt to open it with write-permissions as well
which fails under Windows95. Is there a way I can tell LabVIEW
to relax all locking on the file itself so that I can view it with
wordpad or others?
Andrew Berkley
Department of Physics
University of Maryland
(5,858 Views)
> wordpad or others?
In LV you can look at changing the Deny Mode setting on the file
Open function. You may also want to use this in conjunction with
the Range Locking if you do allow the other app to modify the file.
Both of these are in the File I/O > Advanced Palette, and you will
need to turn on the Deta
iled Diagram Help in the Help window to get
more information on the parameters.
The other option is to look at the help on Notepad. I'm not at a PC
right now, but many text editors can be launched with a view or
noedit flag, disabling their editing features and allowing them to
open files they don't have write access too.
Greg McKaskle
(5,858 Views)
In article <377CC578.6975511C@austin.rr.com>,
>> wordpad or others?
>need to turn on the Detailed Diagram Help in the Help window to get
The default deny mode is to allow all other users to read/write the file.
Somehow it still doesn't work. I open the file with the advanced open VI
and leave the deny mode unwired (which should allow all other users to access
the file) and still when I start up wordpad or word it complains that the file
is in use. Any ideas? The real reason for this is that it would be nice to
run an ftp server on the machine so I can check the data files from elsewhere
as labview is running. The FTP server cannot open the files for the same
reason as word or wordpad, etc.
Andrew
(5,858 Views)
If I were you, try different locking settings. Sometimes documentation is
wrong as to what the default is. If it turns out not to work, this may be
a limitation
on a particular platform; so please look it up in the
knowledge-base and/or report it.
Greg McKaskle
(5,858 Views)
