File Path "\\\\"
I have a customer with a server that I am trying to save some files to.
The path is \\\\AST\home\public.
I am thinking the 4 \ is giving me problems.  I was doing some research and server paths usually start with just 2 \ (i.e. \\AST\home\public)
Any suggestions on how to handle this?  Do I just remove to 2 \ or is there a more elegant way?
Dan Shangraw, P.E.
(1,790 Views)
It is weird that it contains four "\", my search also resulted in "\\" only and not four.
Santhosh
Soliton Technologies
(1,741 Views)
What is the OS of the server?
Is this a path datatype or a string?
If this is a plain string and is set to \-code display, "\\a\b\c" would show as "\\\\a\\b\\c", also duplicating the other ones. Not quite the same.
How are you communicating with the server? Is this just a network shared drive?
In what sense is it "giving you problems"? (error messages, etc.) What have you tried? What problems did you get when using only two at the beginning?
(1,724 Views)
Could it be that the other backslashes in that path are actually double and you missed that? In that case your customer simply copy-pasted the path from a C source or something else using \ escaping. A UNC server name does look like \\\\server\\share\\path in \ escaped form as used in C code.
LabVIEW strings or paths don’t use that unless you set the string explicitly into \~Code display mode.
There is another path prefix in Windows that is \\?\ or \\.\ which indicate to Windows to skip path length limitation for file respectively device paths but that is a very special kernel detail.
Rolf Kalbermatter  My Blog
(1,718 Views)
Found the problem.
Bug in my code.  I was adding \\ for some reason.
Thanks all
Dan Shangraw, P.E.
(1,670 Views)
