File Read Failure
hi dev
could i get ur modified VI ? Kindly help me to change the data structure of theVI if possible. The explanation is simple.
There are 5 main modes. Each main mode has 8 sub mode. One sub mode contains 55 text controls. Each text control is restricted to 5 chars. I wanna to store 5*8*55 texts in file at last. If user can edit the exsisting text, and store it. (Overwrite the file)
I guess it can help to resolve this. Thanx in advance.
Regs
Karthik
Message 11 of 12
(793 Views)
Hi karthik
Good, you should think and solve the problem, Anyway the thread looks similar as LabVIEW crash memory.cpp ..., You can refer this thread. Try to avoid File read and file write VI in your main VI. Make it there itself. It will work.
In future, Dont Make your data structure complex.
Regs
Kings
Message 12 of 12
(775 Views)
