File Structure
Hi all,
I have all my code in the structure below at the moment (many links among vi in the folder):
c:\LVCode\Test\
If I were to move all my codes, so that they all resides in the location below:
c:\ABC\CDA\LVCode\Test\
Could all the vi in the folder that are linked together have broken links?  Would LabVIEW be able to fix such a small difference in the file structure?  Thanks!
Yik
Kudos and Accepted as Solution are welcome!
(2,861 Views)
VIs are linked to different VIs via relative paths (unless the other VI is inside user.lib/vi.lib)
So you should have no problems.
Ton
My LabVIEW Ideas
(2,846 Views)
That's a sound of comfort.  Thanks!
yik
(2,837 Views)
