File dialog - open button
Hallo
How do I configure the file dialog to display a "open" button and not
a "save" button?
I am using LabVIEW 5.1.
Thank you
Gerhard
(4,234 Views)
Create a constant for the "select mode" input of the file dialog
function and set its value to either "existing file" or "existing file
(use LLBs)"
* Sent from RemarQ http://www.remarq.com The Internet's Discussion Network *
The fastest and easiest way to search and participate in Usenet - Free!
(4,234 Views)
>(use LLBs)"
Thank you for the help.
Gerhard
(4,234 Views)
