File dialog "cancel" appends data
  I'm running a VI measuring I_V data. All fine until I get to the part where the program askes if I want to "replace" or "cancel", i.e replacing, substitutes the current data for the original in the file but canceling seems to append the data to the file. This is not very useful. Have I written the code wrong or can someone suggest a fix
Will.
(2,791 Views)
(2,790 Views)
Attached example should solve your problem.
(2,781 Views)
Smiley Wink Very neat, Thank you.
Will.
(2,764 Views)
