File dialog slows parallel DAQ VI to a crawl....
I have an Labview app that reads a few globals, and has the ability to
stream the read globals to disk. In parallel with this is a VI that
actually does the DAQ. I can call the parallel VI fine using the VI server
functions, however, if while the daq is running, I start to record a new
file, the DAQ VI goes from running at 1000Hz to about 10Hz, as soon as the
file dialog is cleared, the aquisition is back up to full speed. I tried
other (non labview) apps and opening files does nothing to the DAQ vi.
Any Ideas?
Paul Blamire
(3,340 Views)
File dialogs are a little bit time consuming in LabVIEW and do not let
operate other parts of LabVIEW very well if in the same thread. If you
are using LabVIEW 5 or better on a multithreading platform (Win32/Unix)
try to assign the DAQ VI to another thread. This should probably help
for your situation
Paul Blamire wrote in article
<37cd808f_1@einstien.netscapeonline.co.uk>...
server
s
the
> Any Ideas?
> Paul Blamire
Rolf Kalbermatter  My Blog
(3,340 Views)
