File handling
How can I check whether a file specified(it maybe a csv, doc or txt file ) is read-only or not using LabVIEW?
(1,636 Views)
Accepted by topic author madhuvishal
You can read file permissions using the 'Get File Permissions' function.
Read the detailed help to get more information because the permissions value is a set of Booleans which you need to parse correctly.
The snippet below should do what you want though
Edit: I have just realised that the read only flag is the wrong way around. The Read only flag flag will be false when the files is read only and true when it is not
(1,598 Views)
