File i/o operations
hi...actually i am new to labview... i want to do some simple file input output operations.... i tried a few..but now my requirement is to write a set of data such data each data in a new line... so can you plse help me how to do it
(3,326 Views)
What datatype is the data? (array, waveform, dynamic, etc)
(3,318 Views)
If your data is of String type, just insert a return character, or "\n"in code view
(3,309 Views)
Sounds like you are looking for the "Write to Spreadsheet File" VI. If this is not what you are looking for, you have to elaborate on your data justs as altenbach recommends.
Norbert
Norbert
Expert: Geometry
(3,300 Views)
