File missing after install LabVIEW 8.5
Have you looked at the mentioned KB article?
Ton
My LabVIEW Ideas
Message 11 of 14
(1,181 Views)
Thanks all,.
I've read the articles.
First, I uninstall all NI SW
Then, reinstall the LV 7.1 only andI follow the article.
But problem are the same.
Regards
Message 12 of 14
(1,172 Views)
Hi Robert,
There is a KB that describes a similar behavior.  Perhaps you had built a .lib file and the report generation toolkit VIs were now copied into the library, relinking these subVIs and that may be why LabVIEW is not able to find these VIs.
If this is applicable to you, then you will need to find the .lib file that contains the report generation toolkit VIs and delete this .lib file so that LabVIEW can reassociate itself with these toolkit VIs.
This KB is located here: http://digital.ni.com/public.nsf/allkb/4727937D500F94BD86256FA8007F17E6?OpenDocument
To clarify, the issue is only happening in your VI right?  Not in your executable?
Message 13 of 14
(1,150 Views)
Tolga C.
The problem is solved
Regards
Robert
Message 14 of 14
(1,134 Views)
