File path control-how to avoid the user to change the path string
Hi all,
I'm using "File path control" to chose file name. I don't want the user to write the path in the control directly (by typing) but only to choose the file via the button on the right.
I can implement this behaviour with path indicator and button of course. But I belieave that it can be done more elegant - only disable the part with the string - not the whole "File path control". But how? I tried to customize the control but not success.
Is it possible?
jochynator
LV 8.0.1, WinXP Pro
(3,794 Views)
The way I've done it is to make the path part of the control tiny and hide it behind a string indicator.  Then whenever the path control changes value (by pressing the Browse button), I populate the string indicator with the path value.  Here's a sample VI demonstrating this method, saved in LabVIEW 8.0.
Hope this helps,
-D
(3,791 Views)
You can use the coloring tool and make the path control transparent. Customize the control and move the little black object on the left side to behind the browse button.
(3,783 Views)
Waw!
Both thanks! So easy 🙂
jochynator
LV 8.0.1, WinXP Pro
(3,774 Views)
