File permission error when deploying on cRIO
I'm having a "File permission error" when I try to deploy (or run as startup) my application on my cRIO.
Here are the steps I did:
  • Format the cRO disk
  • install the NI software on the cRIO
  • Open my LV project and run the code on the cRIO
  • Build my executable
  • Set my executable as startup & deploy it.
I did those steps on another cRIO (identical) without any problems.
Does anybody have a idea of what could go wrong?
My setup:
Thanks a lot!
Vincent
(3,440 Views)
Hello Vincent,
Could you please try restarting your cRIO?
There are different underlying causes that could induce this behavior.
Also, are you using and CDFs?
Michael Pahl
(3,377 Views)
