File states.ctl missing in the measuring angular position link from NI
Dear Labviewusers,
I need a file that's called states.ctl. It's from the following link: https://forums.ni.com/t5/Example-Code/Measuring-Angular-Position-with-myDAQ-and-Sparkfun-IDG500-Dual...
Is it possible that somebody from NI could mail it to me: 0952958hooff@zuyd.nl
Or that you can upload back to the site, since it is a school project with limited time please as fast as possible.
Thanks already
Martijn v Hooff
(3,537 Views)
A comment was posted on that article with the same issue, but it seems nobody at NI is listening. Sometimes I wonder if NI actually reads the comments in there.
A quick fix for you is to right-click on the instance of the type def and select "Disconnect from Type Def". This will turn the type def enum into a standard enum. You can then recreate the type def.
(3,535 Views)
Hi Martjin,
I couldn't locate the original .ctl so I have made a new one and attached it here.
Just close and re-open the .vi, then when it searches for the .ctl file and cannot find it hit "Browse" and locate the states.ctl attached below.
Eden S
National Instruments UK & Ireland
(3,534 Views)
@Smercurio_fc
Haha, that's what I thought, after seeing the comment of the guy who had the same problem without a solution I called NI.
The receptionist was so annoying and the only thing she said that I had to use the forum. But I thought that it was impossible, so after 5 times asking if she could PLEASE transfer the call to ICT or anything I hung up in the middle of the conversation because it annoyed me really bad ;)!
This is possible to solve the problem, at least I hope, because i don't have the sensor right now, school is over ;)!
@Eden_s
You made my day, thanks for everything
(3,522 Views)
