File tag
Is there a way to modify a file attribute?  I would like to change the author and title attribute of an Excel file being generated with ReportGeneration.  These attributes will later be searched by an electronic document management system.
(2,814 Views)
Hi azteca,
What functions did you use to generate the report? Can you post the code or a screenshot of that portion so we can have a better idea on how you're doing it.
Thanks and have a great day.
(2,787 Views)
