File turns out to be blank
I have a simple VI which takes certain measurement(temperature in this case) at every particular time period, and then saves it to a text file. As per convention, I used the procedure of open/create file,write, close. All this was inside a while loop. The VI runs, and stops as per whenver I want it to by pressing the switch. However, when I open the file it turns out to be blank.
Im attaching a screenshot of the VI.
Thanks, in advance.
Message 1 of 13
(4,710 Views)
You've apparently made up some GPIB functions that you have not provided and you have no idea what is being read since you don't have an indicator. You have no error connections on the subVIs and that is just poor programming. How can anyone help?
Note that GPIB requires a write before doing a read so it's entirely possible you have nothing being read so an empty file makes sense.
Message 2 of 13
(4,694 Views)
I tried with the errors, it still showed the same thing. And I have attached a GPIB write outside the loop as shown.
Message 3 of 13
(4,679 Views)
A GPIB Write outside of the loop is pointless. Since you will not post the subVIs or even explain what is inside or create an indicator on the output of your read, I can only surmise that you are not seriously interested in gettin help.
Message 4 of 13
(4,671 Views)
Ok, I did as you said. I added a indicator at the output. Replaced my sub-vi's by the standard GPIB functions.  It executes fine at the start, but at the second run of the loop, i get an error. I've enclosed a screen-shot.
Thanks for the help so far.
Message 5 of 13
(4,655 Views)
Attached  is a better picture of the block diagram.
Message 6 of 13
(4,643 Views)
You aren't paying any attention. You CANNOT just do a read in a loop. It has to be preceded by the write command requesting a measurement. That means putting the write inside of the loop. This is basic GPIB knowledge and not related to LabVIEW.
Message 7 of 13
(4,641 Views)
Cause pictures seem to tell more than words.
Message 8 of 13
(4,634 Views)
Please use the error in/out connections to enforce dataflow so the read occurs after the write.
Message 9 of 13
(4,627 Views)
Dear Dennis,
any idea as to what the error I now get means ?
Message 10 of 13
(4,618 Views)
