File version info
I am new to using the .NET functionality and I am trying to use the FileVersionInfo to obtain the File Version from an exe in Labview 7.1. I think I have all the .NET framework installed,
but when I try to select the FileVersionInfo from under the System Diagnostics, it won't select it and add it into the invoke node. I can see it there, but if I highlight it and hit "OK" it won't
put it back into my node. What am I doing wrong?
Message 11 of 11
(3,201 Views)
