FileDSN with SQL Toolkit
I wish to use a FileDSN when I connect to my MS Access DB, but it seems
that it's not possible. Only SystemDSN and UserDSN are available. (I
get the same result if I try the Database Browser in the Project menu.)
I've tried using a UserDSN and then it works great. If I change the
Connect.vi to add FILEDSN= instead of DSN= then it works, but I'm not
so comfortable about changing the VI's originally supplied (may cause
problem when updating). Is this LabView limitation something I have to
live with or is there a work-around (or better an update from NI).
I'm using LabView 5.1 Prof Dev
/Nimrod
Sent via Deja.com http://www.deja.com/
Before you buy.
Message 1 of 1
(2,904 Views)
