Fill a combo box based on another one
I'm used to VB and I am having trouble getting my head around some LabVIEW concepts.
If I have 2 combo boxes on a form, how do I fill the second one based on the first?
I have attached what I have done so far (you can probably see how new I am to this!)
The VB code would be
Select Case cboLineSize.ListIndex
Case 0 'GR900
cboLength.Clear
cboLength.AddItem "125 mm"
cboLength.AddItem "15 mm"
cboLength.ListIndex = 0
Case 1 'Type-N
cboLength.Clear
cboLength.AddItem "7.5 mm"
Case 2 'PC-7
cboLength.Clear
cboLength.AddItem "100 mm"
cboLength.AddItem "7 mm"
Case 3 'PC-3.5
cboLength.Clear
cboLength.AddItem "75 mm"
cboLength.AddItem "16 mm"
cboLength.AddItem "4 mm"
Case 4 'K-connector
cboLength.Clear
cboLength.AddItem "60 mm"
cboLength.AddItem "10 mm"
cboLength.AddItem "2.5 mm"
Case 5 'PC-2.4
cboLength.Clear
cboLength.AddItem "50 mm"
Case Else
MsgBox "Not an option"
Exit Sub
End Select
Message Edited by opticyclic on 05-16-2005 01:00 PM
(3,118 Views)
Just fill it using property nodes. The attached quick example shows one possibility. (I only added a few random options for the first three selections).
(3,107 Views)
Here it is. Hope you can understand it,
If you need any explanation about it don't hesitate to ask.
Paulo
(3,106 Views)
Thanks both of you.
Its always good to have two different perspectives on how to do something!
(3,086 Views)
