Fill an array of images
I'm doing a VI to read a video to store it in an array that is possible to scroll from the Front Panel. I don't understand why in my program the array is filled only with the same last frame of the video (See the attachment).
Can anybady help me?
Pier Paolo
(3,606 Views)
Can you attach your vi for lv 8.0?
(3,596 Views)
This is the version of my VI for LV 8.0
(3,593 Views)
Take a look at this thread.   The purple wire is not a copy of data, but a pointer to the Imaq image.  You are creating an array of pointers, but they are all pointing to the same image, which happens to be the last image that got created.
(3,564 Views)
Accepted by topic author Pier Paolo
Upstairs' answer is quite right, and I help to modify the issuer sample simply. more details.
________________________________________________________
Try to make everything Automatic
(3,543 Views)
Thank you very much for the solution of my problem. Now I understand and I attach another solution too.
Pier Paolo
(3,534 Views)
