Fill just a portion of a XY graph
Hello all,
I would like to know if somebody here knows how to fill just a portion on the XY graphs, I'm plotting the displacement versus force and also calculating the area under the curve. The area is defined by two cursors (X1 and X2), what I would like to do is to fill only that portion of the graph (between X1 and X2) not all the plot, I used the fill to option and it fill all the plot completed. PLease take a look on the attached picture for a better reference
Thanks for your help!
Message 1 of 18
(4,476 Views)
Create a second plot with the same data, but remove the out of range data or replace it with NaN. Create the fill on the second plot only.
Message 2 of 18
(4,454 Views)
I would double check the NaN + fill combination, I do not remember it ending well.
Message 3 of 18
(4,444 Views)
Please check this example. It is done using 500 random numbers by creating a supplementary waveform and replacing there with NAN 100 points in the beginning and 100 points at the end.  I hope this is what you want.
Message 4 of 18
(4,415 Views)
Sorry I forgot the attachment.
Message 5 of 18
(4,411 Views)
Fill to NaN appears to work, except perhaps for some tiny graphical glitches on the y=0 pixel row.
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Message 6 of 18
(4,407 Views)
I hope the attachment will be visible now.
Message 7 of 18
(4,389 Views)
Set the y minimum <0 to see the origin of those now not-so-tiny graphical glitches.
Message 8 of 18
(4,366 Views)
Hello Nicku thanks a lot for your help, but unfortunately I cannot see the file you just attached Smiley Sad
can you upload it on labview version 8.5 or lower, that will help for sure
thank you!
Message 9 of 18
(4,362 Views)
Hello altenbach I saw you are a very active and trusted member of this forum, I need to say that I got understand your suggestion making a second plot with the specific section, but what is not so clear to me is the usage of the NaN, I'm not familiarized with that constant and would like to know how it works, can you help explaining that with a sample?
Thank you very much for your advice!
I will appreciate your response
Message 10 of 18
(4,361 Views)
