Fill value of array from Realtime Source
I have an 1D-Array with integer values.
And othersides i get realtime value and both signals are looking equal, just with an shift.
How can I proof that this signal are equal?
My Idea:
I would put the realtime data into an array with the same size of the reference array. And then I would use correlationcoefficient to get the r_xy and later I would comapre that always.
(618 Views)
They are not equal if there is a shift.
If both are infinitely long periodic signal, there is an infinite number of shifts that would align them.
(You seem to start new discussions for the same old problem at a rapid-fire pace with incorrect subject lines. Why not keep it all in one place?)
(590 Views)
