Filter array
Hi everyone,
I am trying to create 2 new arrays from one array on the basis of their value. I want to filter array values as less than and greater than 2. I have tried out a few things but its not working....The below is incomplete but I don't know what else to do,...
(2,974 Views)
Accepted by topic author ms6
You don't need a While Loop, but a For Loop to take each element from array, compare it and rebuild the array only with the filtered elements using a conditional indexing output tunnel:
Lucian
CLA
(2,948 Views)
Hi ms6,
So you want to create one array with all values <2 and one array with all values >2?
What should happen with array elements ==2?
Suggestion:
  1. Autoindex the input array at the FOR loop border.
  2. Use a comparison function of your choice.
  3. Autoindex the elements at the FOR loop border to build the output arrays.
  4. Set the tunnel to conditional and set the condition as needed for each output array…
Autoindexing is very basic LabVIEW stuff, as well as all the options of loop tunnels.
Did I recommend the LabVIEW Training resources before?
(2,946 Views)
