Filter serial port input
   Hi All,
I am sending in a signal from a pic to labview. I am sampling at 480 hz. I can plot it perfectly(i just use a time scaler of 1/480 in the graph) but I'd also like to show three seperate plots... narrowband filter at 0-5 hz, 5-8, and 8 - 30. But I can't seem to implement even a sample filter, I get the message Digital Filter Design Toolkit:  The filter object is invalid. I'm not sure what this is about but this isn't totally necessary to my project but I'm doing EEG waves and separating the signal into three narrowbanded results would be great. Any ideas would be greatly appreciated!
(3,020 Views)
Thanks for your post and I hope your well today.
Ive noticed you've not received any support thus far.
I would like to look into this issue tomorrow (when im in the UK office), to see what I can find out.
Are you still having an issue, an update would be great!
What version of LabVIEW are you using? and which toolkit are you using - im assuming you have the DFDT toolkit installed.
Kind Regards,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(2,983 Views)
