Filter values from string, i want to get only certain values!
I have a serial values, from sensor rpm.
In this example it goes from 5089 rpm to 10452rpm.
I want to build a table with fixed values, ie: 5000, 5500, 6000,... i adjust the increments.
I want to search in the array numbers the value > or = than the number in table.
For example, if i have 5000 i want to search the next value > 5000, in this case 5089.
If the next value is 5500 i want to search value > or = than 5500, in this case 5505....
so, saved in the array this values which depent from the increments of parameters. I got the values to search, but i didnt get saved the correct values..
I attached the example with file numbers.
Any help?.
Thanks.
(2,998 Views)
Hi Fonsi,
The function that probably best fits your needs is Threshold 1D Array. The online help for this function says:
"Compares threshold y to the values in array of numbers or points starting at start index until it finds a pair of consecutive elements such that threshold y is greater than the value of the first element and less than or equal to the value of the second element."
The output value is a fractional number you just have to round to +infinity to get the array index you are looking for.
I am attaching an example.
Hope it helps.
César Verdejo
Training and Certification | National Instruments
(2,998 Views)
Hi Cesar, Thanks it worked!. I got.
(2,998 Views)
