Filter
hello, I am using the DMM 4065, the measurent are the resistence, but the resistence is low resistance, and it have variation in mili ohms, for example, the first measurement is 0.180 ohms, the second 0.184 .......0.181.......  and i need that the measurement to be constant. and I don´t know what filter i can to use.
the labview 2016, win 7 32 bits
tanks..
(3,408 Views)
One of the only things worse than posting a picture of your code instead of the VI itself is to post a Word Document with a Picture of your code!  Post the VI!
One of the easiest and simplest low pass filters is an Average.  Take 10 (or 100) measurements and use the average.  If you want to make sure that you didn't get a "spike" in the middle, compute the variance and reject the measurements if the variance is too large.
Bob Schor
(3,392 Views)
tank for your answer
(3,382 Views)
Here is the "filter" --
If you know how to take a measurement, you should know how to take 10 measurements (you can take them every millisecond, or every 10 milliseconds, or every once in a while, it's up to you).  Do you know the word "average"?  If you have 10 measurements (I hope you have them in an Array), do you know how to get the Average?  Do you know about Variance and/or Standard Deviation?
If this is too taxing, you can look in the Mathematics Palette under Probability and Statistics.
If you can move a Word Document from one PC to another, you can move a VI.
Bob Schor
(3,360 Views)
