Filtering Integer from .xls File
Hallo all,
I have an excel data. It contain Integer , String , and Picture  (I attached a snapshot of it).
How can I take / filter just the Integer (In Snapshot , it is indicated with red font), and put it into an array, so i can process it.
Labview just provides functions to read String or Integer from a file.
Any Suggestion would be helpful.
Thanks in advance
Jason
(3,366 Views)
Hi Jason,
please have a look at the following example:
[broken link removed; example no longer available]
regards
timo
(3,351 Views)
and here´s a tutorial
How Do I Read or Write to Named Cells or Named Ranges in Excel Using the LabVIEW Report Generation Toolkit?
http://digital.ni.com/public.nsf/websearch/180EA23CF468B3C186256EA2007BE83A?OpenDocument
(3,349 Views)
Hallo
Thank you very much.
But here i can not run that vi . Labview said error (Attachment).
Regard
Jason
(3,346 Views)
you got an newer version of Excel,
select value2 instead of value
(3,333 Views)
