Filtering Noise cDAQ
Dear all
currently we are developing a new test stand measuring forces with load cells. Their singal is given in Volts (5 +-5 V). We are using NI-9201 cards and a cDAQ-9185 chassis. Unfortunatelly, our signals are noisy. Normally the singals should fluctuate between +-2 N (+-0.004 V), but we measure fluctuation between +-40 N (+-0.08 V).
Is there any way to filter the noise internally via LabVIEW or externaly by installing a filter?
Many thanks in advance.
PS: By using Arduino with 16bit ADC converter (ADS1115), we are having a filtered signal without spikes.
(3,225 Views)
What you describe sounds like a shielding/grounding problem.  It is often a lot easier (and more effective) to eliminate noise by proper wiring than to try to filter out noise "after the fact".
Bob Schor
(3,169 Views)
According to the data sheet here, https://www.ni.com/pdf/manuals/373783a_02.pdf
the 9201 is +/-10V and 12bits, the resolution is approximately 0.004, probably not going to work for you.
(3,165 Views)
