Filtering in frequency domain
Hai. I am new to labview and signal processing. I am working on a program to reduce the noise in the signal. I converted the time domain signal to frequency domain using FFT and filtered the signal using several Butterworth band pass filters and took IFFT on individual filter outputs and recombined them by selecting the minimum values.
The problem is, the reconstructed signal has some sort of symmetric appearance and the local spikes seen in time domain signals are getting concentrated at the end of time base rather being seen at desired points on time base after processing (Pls check the attachment). I can't understand the problem. Please help me in this. Thanks in advance
Message 1 of 11
(7,079 Views)
Please attach your VI. Without it, we cannot see what you filter and what means "processed signal".
Norbert
Expert: Geometry
Message 2 of 11
(7,052 Views)
if my memory serves me correct (and coming from 2d FT) you make a basis transform into Frequency Domain then filter with a lowpass (to ignore the high frequency "noise") and transform back.
there are a lot of (ipython/jupyter) notebooks on fourier transform out there,
which i think might help you get a better understanding, this one looked quite good:
http://calebmadrigal.com/fourier-transform-notes/
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 3 of 11
(7,024 Views)
I have attached my vi. pls check it
Message 4 of 11
(7,015 Views)
Thanks for the link. It's very useful to understand the basics
Message 5 of 11
(7,014 Views)
plz add the data your working on as well if you could.
Message 6 of 11
(7,008 Views)
Try using this file
Message 7 of 11
(6,990 Views)
so i played a little with your code and noticed several things:
* you shouldn't have 3 lowpass filters (from which you choose the minimum)
* your lowpass filters don't need a 'high-cutoff' point (it is ignored, when lowpass)
otherwise i don't konw butterworth filters, but even only one produces the same behaviour as you described.
what i did was to create a filter myself, for wich i shifted the FT and zeroed (as many as i wanted) elemetns from left and right (bc its symmetric).
you can have a look at my messup of you code, jsut plug in the .txt file and run it,
it shows you the results for different amounts of zeros
sorry cant do more
Message 8 of 11
(6,961 Views)
Thanks for your effort. Can you send a lower version of your code. I am using Labview v15
Message 9 of 11
(6,946 Views)
here you go
Message 10 of 11
(6,922 Views)
