Filtering numbers in an array
I have data in an 1d array and I want to remove the points less than a set value.  The points could also be changed to 0.
Thanks in advance for any help.
Paul
(2,909 Views)
Paul
if you only want to set the values<threshold to zero, see the attached code snippet:
(2,900 Views)
