Filtering selected folder
I have set the Browse option of a path control to folder. In the folder selection dialog box I don't want to list a folder if it contains a file with specific name, say expt.xml. Is there a way to do this?
Girish
(2,349 Views)
It can't be done with any of the built-in dialog boxes.  You would have to code your own dialog box.
(2,331 Views)
... which, as I recall, isn't all that difficult (I vaguely remember doing this for myself about 5 years ago ...).  And, if you "roll your own", you can arrange the choices however you wish.
Bob Schor
(2,289 Views)
In the properties of the path control you have Broswe options. Set a pattern to e.g. *.txt. Avoiding single files is hard.
Qestit Systems
Certified-LabVIEW-Developer
(2,269 Views)
